Results 1 to 6 of 6
Thread: Diesel Additives...do they work?
    May 2002
    Stratford, Ct. // Stoddard NH
    Default Diesel Additives...do they work?
    I have a new VW with a turbo diesel...apprently they have some pump issues which may be due to how dry the new ULSD fuel is....anyway I found this article while doing research to find the best additive to lube my pump.
    I figure it my be good info for those of us who want our DS-4's to keep clickin' away also.
    Figures...I buy 2 vehicles with pump issues....none too smart.
    Here is the article...let me know what you think.
    http://www.dieselplace.com/forum/sho...d.php?t=177728
    Kennedy exhaust @128k ..zoom!
    Kennedy FSD cooler @ 135K
    New chain and gears @157K
    Very interesring. I didn't see Red Line in there.
    May 2002
    I'm sure they didnt test every manufacturer,,,I thought the results were real interesting seeing as I use the Lucas additive and Power Service....why bother?
    Feb 2008
    Calgary AB. Canada EH!
    I use Power Up for diesels. I don't know what the specks are but I know my mileage is significantly improved when I use it as well as a slight power improvement. $2.00 per 100 liter fill. (3.73 liter = 1 U.S. gallon)
    93 2500 - best truck I ever owned
    Sold
    98 GMC Sierra 1/2 ton 4X4 EC SB Dark Blue
    3"turbo down to 4" back.
    Remote PMD
    Was S then F code now SSD ECM (used - it was cheap - not my first choice)
    Apr 2002
    Central Florida
    I have been using the Stanadyne and when I cannot get to the supplier, Amsoil. No wonder I needed a new IP after only 90K of use. That was my third pump, put on at 110,000 miles by the dealer just before the warranty ran out on the PMD issue.
    Guess I'll switch.
    1999 6.5 Suburban with factory towing package, 200k miles, 4-inch exhaust, marine injectors, SS Diesel ECM, Amsoil front to rear, OPS mod, Battery bolt mod, 2-0 battery wires, oil line mod, remote mount PMD/FSD, main bearing girdle, rebuilt trans in 2011
    1982 Suburban, 6.2 unknown miles, rebuilt injectors, rebuilt IP, new front of engine, including rad in 03, rebuilt trans in 2010, new oil pump, rear main seal, main bearing girdle 2012
    May 2002
    I found a guy in Texas who sells 5 gallon cubes of 100% high quality bio....I cant get it around here in small quantities...everybody wants me to buy 10,000 gallons!
    I figured to make 2 percent bio that would be about 2.5 quarts per fill up on the big truck (assuming 30 gallons)... a little pricey..would only last 8 fills..
    I'm going to try the XPD...not as good as 2% bio...but more cost efficient and meets the strict spec as well.
