Results 1 to 9 of 9
Thread: Probably a re post but how do I time my new injection pump
    Dec 2010
    Connecticut
    Default Probably a re post but how do I time my new injection pump
    About to remove my pump (finally finding time to work on the truck again after moving) and wanted to know if I can do a home time on the pump or if I need to bring it somewhere?
    Thanks,
    Nate
    1997 GMC 2500 6.5 4 x 4
    Kennedy Quick Heat Glows
    Stanadyne "bullet proof" PMD
    Put the pump in with the shutoff solenoid vertical. that should be close enough to get it running. To get it any better you need a way to read TDC offset from the PCM.
    I have a little trick that I have used many times.
    Mark the old pump and the timing cover with a clean "ONE STRIKE" chissel mark across the IP and the cover.
    Remove the Old IP
    Now with the new one sitting side by side with the old one, carefully measure using a straight edge and a rule, the location of your mark on the flange of the OLD IP
    The investment castings that are used in the Body of the IP are very close to the same for all of the Pumps made.
    If you pick a clean flat spot on the side of the housing to pace your straight edge, and do the same on both pumps, you can locate a reference mark on your new IP that will be very very close on your new one.
    The computer does the actual timing and as long as the IP is in a position that the stepper motor can adjust the timing within its limits it will work.
    To get the absolute best setting requires a tech tool or other form of scanner that can access the ECM and do the TDC learn/Time set.
    This little trick will get you close though.
    If after the engine warms up, and you DO NOT get a SES light then your Good to go, at least until you can get the thing scanned.
    Good luck
    Missy
    Dec 2010
    Connecticut
    Thanks People...I rushed and did not mark the injector lines when I took them off the back of the pump! Is there a diagram showing which cylinder goes to which port on the back of the new pump?????
    Try this:
    May 2002
    Stratford, Ct. // Stoddard NH
    cmon...coupe I been waiting for you to get that girl running!!
    I'm still waiting to see if you got a good deal on that truck..
    I hope you moved closer so we can get that thing timed up!
    Kennedy exhaust @128k ..zoom!
    Kennedy FSD cooler @ 135K
    New chain and gears @157K
    Dec 2010
    Connecticut
    Quote Originally Posted by rameye View Post
    Me Too hahahahahahaha
    Dec 2010
    Connecticut
    Try this:
    Thanks DMax!!! Perfect!
    Dec 2010
    Connecticut
    Pump is off...bring on the rebuild/reassembly
