What's the thread pitch of the bolts that affix the oil pan to the block and to the timing cover. I've got a few timing covers with stripped holes for the pan and thinking of getting inserts or bushings to fix this issue.
Is it M7x1.0?
Is it M7x1.0?
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
I expect that if you plan to use inserts you can choose whatever thread style you want provided the bolt fits through the oil pan hole and you have a supply of the appropriate bolt on hand.
I prefer to use fine thread bolts in aluminum.
2005 Chev K3500 CCLB
Got a helicoil kit at the local bolt bin.
It was a M6x1.0.
I was trying to just buy it online and say some bucks, no such luck. Dropped by got it identified and bought the kit.
This will be here for the next fella looking for that info...
