Thread: 1996 Chevy Tahoe Cummins Conversion
    Sep 2006
    Default 1996 Chevy Tahoe Cummins Conversion
    I just bought this truck yesterday and thought I would share with everybody some pictures of the conversion. The 1993 VE pump Cummins runs very good and the drive train seems very solid other than shifting into 3rd gear. I have to double clutch it in order to shift into 3rd without grinding it. I also don't like how high it is and I'm going to see what I can do to lower it. It's so high that you feel that you're disconnected from the road. The vehicle goes down the road with more body lean and body roll than I used to. Other than that, it's a nice vehicle that was previously taken well care of.
    1993 Cummins 6BT VE pump
    NV4500 5 speed transmission
    3.42 gears
    Transfer case and differential from 1 ton Chevy truck
    6" Rancho suspension lift
    3" Body lift
    Lots of clearance between engine and radiator. One problem I see is if I remove the body lift, the fan will contact the hood. Looks like I'll need to use an electric fan to get around this issue.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Sep 2006
    GM A/C Pump
    Engine to transmission bracket
    NV4500 Transmission
    Transfer case out of a 1 ton Chevy truck
    Plenty of clearance between engine and transmission. Looks like I might be able to remove the suspension lift
    Aug 2002
    Florida
    Cool Cool Truck
    Cool Truck Can I Buy It When Your Done With It?
    P PUMP AND AN INTERCOOLER & THEN IT WOULD BE EVEN WAAAAAAYYYYY COOLER!
    David duPont
    Suburban Auto & Marine Sales Inc.
    spdgofast@comcast.net
    Sep 2006
    Quote Originally Posted by spdgofast View Post
    An intercooler will be one of the first things to go on it. It'll eliminate that turbo to intake cross over pipe so I can remove the body lift. However, I will not be installing a P-Pump. The VE pumps is so much quieter and it already has more power than you know what to do with.
