John, I'm not sure if this completely answers your question, but...
When Ronnie built my engine, I kept the manifolds as I was having them ceramic coated. Ron said to make the mani mounting surface true as he will make sure the block is true. I took the mani's to a local machine shop (actually the back room to a local NAPA store) and he simply put them on a large belt sander. Haven't noticed any leaks to date.
