Results 1 to 8 of 8
Thread: lb7 upgrade
    Default lb7 upgrade
    adding twin turbo and upgraded injection pump .shouldnt have to up grade bottom end. but i am replacing head bolts with studs( recommened by shop). your thoughts on doing one stud at a time starting with the last bolt in gm torque sequence and working back one at a time.performance shop where i got the parts have done it before no problems save taking the heads off
    Dec 2002
    Teton Valley, Idaho
    If you're going to spend the $$$ on GOOD studs (ARP?) why not spend an extra $150 for new head gaskets and do it right? This isn't really the job you want to do half a$$ed, and this is a good time to clean the head ports too, and any valve work that may need done. Can't do that too well on the engine.
    Default Ib7 Upgrade
    i mentioned the same to my son (his truck his money) just looking for back up thanks will tell him. guess i am on wrong page will move to performance page
    The one in-one out method has been used by quite a few and with seemingly good success. I'll caution you on two things:
    1) Connecting rod strength-kaboom
    2) opening up a can of worms when removing injector lines-dirt and rust
    I did not see where you were located.
    Default Capb2
    Located Owen Sound Ontario Canada . Glad I Pulled Heads Off Right Bank Head Gasket Leaking
    Did you find a pile of rusty residue in the injector inlet bowls?
    Default cap b2
    waiting for tool to pull injectors. right side gasket pitted and rusty around back right 2 cul. one cylinder surface rust on cyl.question when ordering head gaskets i have been told to check part number on gasket i did they are both different .right side #5600 left side #5630 is that normal
    Default rusty residue
    found residue in 3 injector cups and oil in 1 / heads have been redone at machine shop . new cups .10 thous taken off heads new intake guides and valve reground. glad the heads came off .parts are in ready to put it all back together.memory is not what it use to be . should be interesting getting it back together been a month since we took it apart.
