1/4 turn of fuel is too much fuel.
Will smoke, will get poor fuel mileage, and will make high EGT's that you're not aware of because there isn't a gauge installed to monitor it.
The amount of fuel your're talking about is to be used with a Turbo.
With that said, I'd calibrate the injection pump for a later model 6.2 J series engine, use the long-body injectors with the lines from the 6.2 engine (since you used 6.2 heads).
I'd take the shift down and 19mpg over the 14 any day.
If you want power and fuel economy, step up to a Banks turbo system.
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
