Results 1 to 8 of 8
Thread: smoky 6.6 duramax
    Feb 2012
    Canada/ontario
    Default smoky 6.6 duramax
    I have a 03 6.6 duramax and it smokes while idiling at a traffic light not quite a black smoke more grey in colour and it does it periodically. Also there seems to be a popping sound from the muffler almost sounds like a paint can popping when left in the heat.
    Any suggestions as to what may be causing it?
    Feb 2002
    KG, Va
    Smoke at idle is usually a sign of injectors going bad. Check your balance rates on them when the truck is at operating temp with the truck in park to get some idea of how they are working. Post the results back here.
    '02 2500HD CC SB 4X4 D/A, Kennedy headlight kit, OilGuard bypass, Nicktane fuel filt, Pred 1.04, Autometer Ultra-Lites, ARE Z-Series, DX-959, KL203, Xferflow filler kit, Kennedy twin lift pump kit, Alpine CDE-HD137BT, JL Audio C2-650X Evolution Series speakers
    May 2001
    Morgantown, W.Va. USA
    You will need some type of scanner/tuner to check balance rates, or off to the delaership.
    Jeff
    2013 Caprice PPV 6.0L
    Dec 2002
    Teton Valley, Idaho
    You might also check the oil level in the engine... If it constantly seems to overfill itself, you're looking at an injector problem.
    Feb 2012
    Canada/ontario
    Would a OBD II scanner help me out with this problem, will i get a code coming up?
    Would a collapsed muffler or cat cause the same problem, i don't think its injectors the smoke is quite white in colour.
    thx for the reply
    Quote Originally Posted by lvallati View Post
    thx for the reply
    Almost always, smoke caused by failed injectors is white or gray. Seldom will there be a DTC (code) to help with diagnosis. Keep a close watch on your oil level!
    The muffler or cat can cause running issues, and occasional smoke issues, but that's not your current issue. Failed injectors, causing the smoke in your case, will cause elevated exhaust temperatures and an overheated cat. This can, and often does, create heat related noises (popping) in the exhaust system, due to thermal expansion/contraction and excess fuel detonation. The extreme heat and fuel detonation will destroy the cat in a very short period. Driving it in this condition may cause your repair bill to skyrocket.
    Feb 2012
    Canada/ontario
    I will surely get it diagnosed thanks for the info.
    Being a 2003 in Canada I'd doubt that it has a cat, but I definitely sugest getting the injectors done ASAP. Running with bad injectors does bad things to pistons.
    I recommend all 8 injectors with NEW supply lines. Add secondary filtration, lift pump, and quality additive to help prolong the life of your new injectors.
