are these 6.5 turbo injectors ? 0430 211 097 372-3 973...
will these work on a 6.5 short block with 6.2 heads and a 6.2 injector pump?
What year are the 6.2 Heads?? The 88 up 6.2 heads are the same as 6.5 heads. The 973 bosch are for 6.5 turbos.
Check this link out for injector data
http://www.usdieselparts.com/index.c...-injectors.cfm
JJ what are you trying to accomplish. I made a post on your thread about lines.
If I can help let me know
Michael
94 Chevy 6.5 Turbo HD 2500 Flat Bed-Dump-FOR SALE
BD Power - 4 inch exhaust and Downpipe, Towing chip
FSD cooler relocated and vented behind d/s battery
Jet Performance built 4L80E-HD deep pan
410 semi-float rear axle
Many other add ons.
93 Chevy k3500 HD- Single Rear Full Float Axle-Project
Do you know what year the heads are he used? Since your using 6.2 heads you need to make sure there 88 and up heads(there the same as 6.5 heads) the valves are larger.
If your running 973 injectors without a turbo that could be your problem,
The 4911 was the best pump made.
Michael
Many other add ons.
