Results 1 to 6 of 6
Thread: Any news on the CAMs from Diesel Depot?
    Dec 2002
    Terre Haute IN
    A while ago I remember reading about some modified CAMS, has anyone tried one?
    99 K2500 GMC Ext Cab, 6.5TD, Heath ECM reflash, TDC Offset -1.80, Bumped Optic, FSD Isolator, Turbo Master, KD 3.5" Exhaust, 4.10s and 33x11.50, Intercooler is next.
    98 Burb 350 1/2T/4l60/246/10Bolts - Wifes Ride
    80 Olds Cutlass 6.2/Studded/700R4/12Bolt 3.30s/IP=4544 Juiced by JK/Best MPG=30
    79 Olds Cutlass, 410ci/700R4 - Currently Restoring
    1992 Mitsubishi Eclipse Turbo, currently 12PSI max boost
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Email= Dr.Diesel@gmail.com WA9SDJ
    dieseldummy Guest
    I ran one for 20K or so. It seemed to produce cooler EGT's, but didn't really notice an increase in power.
    Dec 2002
    Terre Haute IN
    Have you stopped running it? Engine nuke or sell the truck?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    dieseldummy Guest
    Engine blew up, trying to get it going again. Building a 6.2 to put in place of the 6.5, just taking a long time with the funds available... I do plan on running the diesel depot cam again though.
    Jan 2003
    Old Line State
    Are you mounting the turbo on the 6.2?
    aka:Tim
    `91 V2500 Scottsdale Suburban:6.2 4L80E 4"Lift 35s
    `92 K3500 SLE SRW:Peninsular6.5TD Peninsular 5spd
    `72 K20 CustomDeluxe Highlander CustomCamper
    `72 K20 CheyenneSuper CustomCamper
    `72 K2500 SierraGrande
    `71 K10 CustomDeluxe 6' Fleetside
    dieseldummy Guest
    Yeah, It will be the same as the 6.5, just have a 6.2 for a base. All the addon's will stay the same.
