Thread: Truck shudders
    Jan 2005
    L.I. NY>
    Default Truck shudders
    I have had this problem for quite a while but seems to becomming a little hasher as of late.
    Right at 45mph when the converter locks up and is given light throttle the truck shakes like a bad U-Joint untill 48 mph then completely disappears??????
    Really feels as if it were the engine rather than the drive train which makes no sense at all.
    Maybe something in the converter?
    If I lift my foot off the throttle smooth as silk.
    A little puzzled
    Dave
    99 sub 2500, 326,000mi, 4:10, 265-75-16 rubber, remote Dtech fsd and turbo master from Heath Isspro pyrometer and boost gauge-Kennedy, 1.94 TDCO, 3" custom bent exh.
    07 Suburban,08 LMM, Allison 6 speed.
    Jul 2003
    Allentown, PA
    What's the level and quality of your transmission fluid?
    Jan 2005
    L.I. NY>
    The color and level is ok and it smells ok.
    Bought the truck w/69K on it and 199 now with no filter or change. Against my principals to let it go this long,but have heard more than once if the fluid looks and smells ok leave it alone?
