Originally Posted by
phantom309
what parts are included in the cooling upgrade?
Nick
If it's on your 94 you will need two new thermostats, crossover, and a high output water pump at the least. While you are in there it wold be a good time to update your timing chain if it isn't a fresh one. Or a gear drive.
Might freshen up your heater hoses and lower hose too. IIRC, you will be changing the uper hose to fit the new crossover.
While everything is out clean the radiator inside & out as well as the a c condensor and oil cooler. You wouldn't believe all the trash and dirt that collects in and between these.
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
