Results 1 to 17 of 17
Thread: What motor oil do you use and why?
    Arrow What motor oil do you use and why?
    I use Shell synthetic in my Duramax because of the 7500-mile drain interval and how clean the oil remains over the time it's there. And, it's available at WalMart. I might use Mobil Delvac 1 synthetic, but it's much harder to find.
    For a 6.5, I tend to use Chevron Delo because of the 3K drain intervals and the soot load.
    Apr 2009
    Sheridan, Oregon
    I use the Rotella full synthetic. It has quieted the rattle some. I got another 1+ MPG. It's cheap at the Wallies. And I read a report by a independant oil analyzing firm that said that is the best full synthetic on the market for the light duty diesel engine. That it beats the requirements by a long shot. I'd post the report but I have changed computers twice now since I saved it.
    2004 Chevy K3500 CCLB DRW Duramax. Stock.
    1992 Sea Ray 300DA. 30 plus foot Express Cruiser on a trailer. 13,500# boat and trailer and 69' of combined length rolling. Over length/width permitted load.
    SOLD-95 GMC K2500 SLE 6.5L TD, Relocated PMD to bumper #9 res., Custom Lowes special induction tube, Triple gauges on the pillar EGT, Trans, Boost, High Idle Mod, TCC-Lock up Mod, Custom Back up camera, DIY Manual Wastegate Controller, 4" from down tube to 5" stacks, Vac Pump Removed,2007 wheels, WMI by Cooling Mist 8gph @3psi 11gph on demand
    Michigan
    Default Shell Rotella Line used here
    The 95 GMC gets Rotella T6 5W-40 synthetic, also running an Amsoil bypass filter. I run 10-12K oil change intervals, but change the PF1218 spin on every 2500 miles and add a quart.
    Have been running RotellaT 15W-40 in the 2005 Dmax and 7500 mile change intervals. EGR disabled since new, oil stays clean, starting to discolor when changed at 7500 miles. Also run with the turbo vanes open during light cruise which also reduces soot in the oil.
    TDP member #14
    Mobil Delvac black jug - 10K intervals
    Sep 2006
    Brooker, FL
    Rotella T 15W40 mineral, 4-5K mile drain interval (8T motorhome loads the engine a lot more than a pickup or Suburban). I was a field engineer with Shell many years ago. I may consider switching to synthetic due to ULSD, but haven't seen a convincing study about the effect of ULSD.
    Apr 2010
    Rotella T6 synthetic.
    5W40.
    Yup, I drank the cool aid:
    http://www-static.shell.com/static/c...rotella_t6.pdf
    Mar 2002
    Lecanto, FL
    Are there any straight weight synthetics? The previous owner was using a Shell Rotella T5 synthetic blend. I've got about 300+ miles on the truck since I bought it & she does no seem to have much if any blow by. Unknown actual engine mileage. Have I gotten the impression that switching between full synthetic & conventional is a non issue? I have always run Rotella T1 in both my gas & diesels but being out of the loop thought I'd get some more input ~
    Thanks!
    96 1500 6.5 Silverado
    81 Malibu ~ 75 Vega Wagon
    Lecanto, Florida
    Dec 2005
    Klamath falls/keno Oregon
    Amsoil, I have 408,000 miles on the cock.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Quote Originally Posted by spongebob View Post
    My chickens NEVER went that far. Impressive.
    Maplesville, AL - Home Base
    I feel like a beginner with only 217,000 on my '06 LBZ.
    Ed
    KM4STL
