Results 1 to 17 of 17
Thread: What motor oil do you use and why?
    Arrow What motor oil do you use and why?
    I use Shell synthetic in my Duramax because of the 7500-mile drain interval and how clean the oil remains over the time it's there. And, it's available at WalMart. I might use Mobil Delvac 1 synthetic, but it's much harder to find.
    For a 6.5, I tend to use Chevron Delo because of the 3K drain intervals and the soot load.
    Apr 2009
    Sheridan, Oregon
    I use the Rotella full synthetic. It has quieted the rattle some. I got another 1+ MPG. It's cheap at the Wallies. And I read a report by a independant oil analyzing firm that said that is the best full synthetic on the market for the light duty diesel engine. That it beats the requirements by a long shot. I'd post the report but I have changed computers twice now since I saved it.
    2004 Chevy K3500 CCLB DRW LB7 Duramax. Stock.
    Michigan
    Default Shell Rotella Line used here
    The 95 GMC gets Rotella T6 5W-40 synthetic, also running an Amsoil bypass filter. I run 10-12K oil change intervals, but change the PF1218 spin on every 2500 miles and add a quart.
    Have been running RotellaT 15W-40 in the 2005 Dmax and 7500 mile change intervals. EGR disabled since new, oil stays clean, starting to discolor when changed at 7500 miles. Also run with the turbo vanes open during light cruise which also reduces soot in the oil.
    TDP member #14
    Mobil Delvac black jug - 10K intervals
    Sep 2006
    Brooker, FL
    Rotella T 15W40 mineral, 4-5K mile drain interval (8T motorhome loads the engine a lot more than a pickup or Suburban). I was a field engineer with Shell many years ago. I may consider switching to synthetic due to ULSD, but haven't seen a convincing study about the effect of ULSD.
    Apr 2010
    Rotella T6 synthetic.
    5W40.
    Yup, I drank the cool aid:
    http://www-static.shell.com/static/c...rotella_t6.pdf
    Delvac 1 5w40. My 2005 just sold. It had 8,000 miles on the oil (with bypass filtration) and the oil looked like new on the stick just a bit of darkening. Golden look on the stick. Partly oil, partly filtration and even moreso mild yet strong tuning...
    I've gone 12k on my 2007 with no bypass filtration.
    My 2012 got Delvac 1 at 300 miles before our trip to CO
    All trucks still use the factory breather/PCV system. The 2005 and 2007 will consume about a quart in 5-7k.
    My 2002 uses Cenpeco Racing 20w50 (petroleum) due to the extreme naure of operation of this engine.
    Nov 2001
    Aitkin, MN
    Rotella 5W-40 synthetic, because I can use it in everything I own except the 2 cycles. My oil change intervals are about what they were when I used non-synthetic, but I don't worry if I go a bit over.
    The 6.5s use exactly the same amount of oil as when I ran non-synthetic Rotella, but the oil doesn't get as dark, as quick. Hmmm...
    As my gas cars approach 150K to 250K miles, I get real lax about change intervals. Towards the end, our 02 Century was getting changed twice a year. (My son overheated it at ~ 250K. Neither he nor I realized the gauge never makes it to the red, no matter how hot it gets. So, it wasn't in the red, & he nursed it a mile to work. Head gasket, cracked head - pretty normal for a 3.1. I don't figure the car owes me anything. Was shopping for another Century when a Saturn caught my eye.)
    May 2001
    Morgantown, W.Va. USA
    Rotella 15w-40 at 5k intervals. I use it because its got a good rep, it's available everywhere, the price is reasonable, and it comes in a 2.5 gallon jug!
    Disclaimer: Rotella's price is starting to get up there a bit, I may try Travellers (TSC) 15w-40 or maybe Wal-Marts brand ummm can't think of the name. They are both almost $5 cheaper per 2.5 gallon jug.
    Of course with oil changes only two or three times a year the extra 5 bucks ain't much of a savings.
    Jeff
    2013 Caprice PPV 6.0L
    Nov 2001
    Aitkin, MN
    Good Day!
    Wow - I was just in Wally's, & was unaware of how much conventional oil has gone up. Most of the name brands were ~ $3.70 a quart. Rotella 5W-40 synthetic, which I use, works out to ~ $5.38 a quart. I'm glad I read this topic; feeling better about my choice.
    Sep 2003
    Feeniks, Aridzona
    I ran rotella synthetic for the first 40K miles on the engine. I switched to Mobile 1 synthetic 5/40 because the store was out of Rotella once and I don't think I'll go back to Rotella. Engine was quieter and it burned less than half of what it normally did between changes. After it gets running again I will stay with the M1 for a while. I do plan to add a bypass filter system to it, as well as add some additional oil cooling.
    Agreed. I could never keep Rotella in my engines, was always adding oil as it vaporized off.
    I use Mobil Delvac black jug conventional and do 10K oil changes, which is about every month during the season. I have about 800K happy miles on seven Duramax trucks using this method and brand. I carry no oil on the trucks, never add between oil changes anymore.
    Interestingly, CAT has stepped away from use of multi-viscosity oils (Rotella 15/40 is just as commonly used in the marine industry) in their turbocharged and aftercooled marine engines for the same reason - breakdown.
    As the oil breaks down, it plugs the aftercoolers with sticky black goo that is residual from the additive package that gives the oil its multi-viscosity properties. CAT now requires a straight weight DELO 30W for my boats twin CATs.
    I had maintenance records from the previous owner that indicated Rotella had been used about half the seasons since 2000, so I had the aftercoolers pulled and steam cleaned, engine oil changed to DELO 30W.
    Dec 2011
    Henderson, Nevada
    I also use Delo 30W from Napa.
    Many years ago I talked with an engine builder and his story was that in the multiweights the chemical structure is " played with " and the oil is almost a polymer . He claimed that nothing would " touch " the carbon that was the result of using the Multigrades. He recommended the straight weights.
    I think the multigrades came into use in an attempt to increase fuel mileage when we had one of our gasoline " crunches". Kinda like puting automatic transmission fluid in manual transmissions to reduce the drag of churning up the heavier lubes.
    Just some of my thoughts and observations.
    I prefer Engine mileage to fuel mileage :>)
    Jerry
    1996 Silverado 2500 TD , stock except for a remote mounted PMD.
    I purchased this Truck 7 years ago from the original owner, had 80,000 miles on it. I Had the engine remanufactured at 100,000 by a local remanufacturer that does 6.5 Engines for the Military. Now has 105,00 miles on it.
    Mar 2002
    Lecanto, FL
    Are there any straight weight synthetics? The previous owner was using a Shell Rotella T5 synthetic blend. I've got about 300+ miles on the truck since I bought it & she does no seem to have much if any blow by. Unknown actual engine mileage. Have I gotten the impression that switching between full synthetic & conventional is a non issue? I have always run Rotella T1 in both my gas & diesels but being out of the loop thought I'd get some more input ~
    Thanks!
    96 1500 6.5 Silverado
    81 Malibu ~ 75 Vega Wagon
    Lecanto, Florida
    Dec 2005
    Klamath falls/keno Oregon
    Amsoil, I have 408,000 miles on the cock.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    My chickens NEVER went that far. Impressive.
    Maplesville, AL - Home Base
    I feel like a beginner with only 217,000 on my '06 LBZ.
    Ed
    KM4STL
  1. Used Motor Oil As Fuel
    By Stratosurfer in forum Diesel Fuel, Bio-Diesel & Fluids Forum
    Last Post: 09-18-2014, 11:18
  2. New motor ,no oil pressure
    By Reddog in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-03-2010, 10:23
  3. Waste Oil Heater Burns veg oil, motor oil, biodiesel etc
    By Murphy in forum TDP Classified ad forum
    Last Post: 02-12-2007, 06:37
  4. Which Motor Oil?
    By Low_Bridge in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-10-2004, 08:41
  5. What Y'all This Of This Motor Oil?
    By ryeguy in forum Duramax 6600
    Last Post: 03-13-2004, 09:40
