Thread: NEW TDCO procedures?
    Jul 2005
    Silver Spring, MD
    i've been browsing through the new GM Techline ESI cd i have.
    It says
    "to do TDCO procedure, run engine until coolant is 170 F.
    turn engine off
    turn to on w/o starting
    floor it for 45 seconds - this resets the PCM TDCO and allows the TDCO to be learned
    then turn off for 30 seconds - allows PCm to power down
    then start engine
    then
    as soon as the coolant is 170 F and rpm below 1500 rpm, a new TDCO will be stored.
    indicated by a slight stumble. "
    also
    it seems like maybe this cd set doesn't have everything the 4 book manual has.. maybe it does. i dunno. it does have every vehicle GM makes from 1996 to current, along with repair instructions for all.
    for example - it notes GM went to metric engines in 1999. not a bad buy for $30
    All who call on the name of Jesus and repent their sins will be saved.<br />1998 k3500 Silverado Dually 4.11 Differential <br />6.5 TD K&N Filter
    TurboDiverArt Guest
    Originally posted by Aryeh Levy:
    ....it seems like maybe this cd set doesn't have everything the 4 book manual has.. maybe it does. i dunno. it does have every vehicle GM makes from 1996 to current, along with repair instructions for all.
    Does the CD set have diagrams? It would be nice to know how this differs from the Helm manual.
    Art.
    Jul 2005
    Silver Spring, MD
    Yeah, there are line drawings showing all the verious parts, and those litle arrows for the screws where they go.
    it's set up topically. the first page for the gm 1998 has:
    Service Manual/Bulletins
    C/K Truck
    Unit Repair
    Transmissions
    0
    c/k truck has
    Select a category:
    Bulletins By Category
    View All Bulletins
    Campaigns
    Preliminary Information
    General Information
    HVAC
    Steering
    Suspension
    Driveline/Axle
    Brakes
    Engine
    Transmission/Transaxle
    Body and Accessories
    Restraints
    then under engine
    engine mechanical
    and 6.5L
    repair instructions:
    Drive Belt Replacement 6.5L Drive Belt
    Drive Belt Tensioner Replacement
    Drive Belt Idler Pulley Replacement
    Engine Mount Inspection
    Engine Mount Replacement Front
    Engine Mount Replacement Rear
    Intake Manifold Replacement Upper
    Intake Manifold Replacement Lower
    Oil Pump Drive Replacement
    Oil Level Indicator and Tube Replacement
    Valve Rocker Arm Cover Replacement
    Valve Rocker Arm, Shaft, and Push Rod Replacement
    Exhaust Manifold Replacement Right
    Exhaust Manifold Replacement Left
    Cylinder Head Replacement
    Valve Stem Oil Seal and Valve Spring Replacement
    Valve Lifter Replacement
    Crankshaft Balancer Replacement
    Crankshaft Front Oil Seal Replacement
    Engine Front Cover Replacement
    Timing Chain and Sprockets Replacement
    Camshaft Replacement
    Crankshaft Rear Oil Seal Replacement
    Engine Flywheel Replacement
    Oil Filter Adapter and Bypass Valve Assembly Replacement
    Oil Pan Replacement
    Oil Pump Replacement
    Engine Replacement
    Engine Oil and Oil Filter Replacement
    Accessory Removal
    Engine Flywheel Removal
    Oil Fill Tube Removal
    Oil Level Indicator and Tube Removal
    Thermostat Removal
    Intake Manifold Removal L65
    Intake Manifold Removal Upper-L56
    Intake Manifold Removal L57, L65
    Engine Wiring Harness Assembly Removal
    Turbocharger Removal
    Oil Pump Drive Removal
    Exhaust Manifold Removal L65
    Water Pump Removal
    Fuel Injection Pump Removal
    Crankshaft Balancer Removal
    Engine Front Cover Removal
    Timing Chain Wear Check
    Timing Chain and Camshaft Sprocket Removal
    Valve Rocker Arm Cover Removal
    Valve Rocker Arm, Shaft, and Push Rod Removal
    Cylinder Head Removal
    Valve Lifter Removal
    Camshaft Removal
    Oil Pan Removal
    Oil Pump Removal
    Piston, Connecting Rod, and Bearing Removal
    Crankshaft Rear Oil Seal Removal
    Crankshaft and Bearings Removal
    Oil Filter Adapter Removal
    Engine Block Plug Removal
    Piston Oil Cooling Nozzle Removal
    Engine Block Cleaning and Inspection
    Cylinder Boring and Honing
    Crankshaft and Bearings Cleaning and Inspection
    Crankshaft Balancer Cleaning and Inspection
    Engine Flywheel Cleaning and Inspection
    Piston and Connecting Rod Disassemble
    Piston, Connecting Rod, and Bearings Cleaning and Inspection Piston Inspection
    Piston Selection
    Piston and Connecting Rod Assemble
    Camshaft Bearing Removal
    Camshaft and Bearings Cleaning and Inspection
    Camshaft Bearing Installation
    Timing Chain and Sprockets Cleaning and Inspection
    Valve Rocker Arm and Shaft Disassemble
    Valve Rocker Arm and Shaft Cleaning and Inspection
    Valve Rocker Arm and Shaft Assemble
    Valve Lifters and Guides Cleaning and Inspection
    Cylinder Head Disassemble
    Cylinder Head Cleaning and Inspection
    Valve Guide Reaming/Valve and Seat Grinding
    Cylinder Head Assemble
    Oil Pump Disassemble
    Oil Pump Cleaning and Inspection
    Oil Pump Assemble
    Engine Front Cover Cleaning and Inspection
    Valve Rocker Arm Cover Cleaning and Inspection
    Oil Pan Cleaning and Inspection
    Intake Manifold Cleaning and Inspection
    Exhaust Manifold Cleaning and Inspection
    Water Pump Cleaning and Inspection
    Fuel Injection Pump Cleaning and Inspection
    Service Prior to Assembly
    Piston Oil Cooling Nozzle Installation
    Engine Block Plug Installation
    Oil Filter Adapter Installation
    Crankshaft and Bearings Installation L65
    Crankshaft Rear Oil Seal Installation
    Piston, Connecting Rod, and Bearing Installation
    Oil Pump Installation
    Oil Pan Installation
    Camshaft Installation
    Valve Lifter Installation
    Cylinder Head Installation
    Valve Rocker Arm, Shaft, and Push Rod Installation
    Valve Rocker Arm Cover Installation
    Timing Chain and Sprockets Installation
    Engine Front Cover Installation
    Crankshaft Balancer Installation
    Fuel Injection Pump Installation
    Water Pump Installation
    Exhaust Manifold Installation L65
    Oil Pump Drive Installation
    Turbocharger Installation
    Engine Wiring Harness Assembly Installation
    Intake Manifold Installation Upper-L65
    Intake Manifold Installation L57, L65
    Intake Manifold Installation Upper-L56
    Thermostat Installation L56, L65, L65-CMT
    Oil Level Indicator and Tube Installation
    Oil Fill Tube Installation
    Engine Flywheel Installation
    Accessory Installation
    Engine Set-Up and Testing
    It also refers to the "paper version of this manual"
    I believe it contains all the information from the paper repair manual, including line drawings.
    For every single GM vehicle from 1996 on.
    it has much more on 1998 on vehicles, but has the service manuals only on 1996, and 1997 vehicles.
    but for $30 from the guy on e-bay...
    Again i believe its pirated, because of the $400 price i saw on helm's website. But i cant be sure one way or another.
