Results 1 to 12 of 12
Thread: Random Reving
    Feb 2008
    Calgary AB. Canada EH!
    Default Random Reving
    My truck will randomly rev for a split second like someone gave the go pedal a quick shot. This has been going on for a few months now. Today it did it twice. Both times the truck was idling in gear. Could this be the last days for the PMD? or is it something else?
    Cheers
    93 2500 - best truck I ever owned
    Sold
    98 GMC Sierra 1/2 ton 4X4 EC SB Dark Blue
    3"turbo down to 4" back.
    Remote PMD
    Was S then F code now SSD ECM (used - it was cheap - not my first choice)
    Jan 2005
    L.I. NY>
    Same thing been happening with my truck for 8 or so years since Ive had it.
    feels almost like some one bumped you at a light or the truck just pops in and out of gear very quickly.
    I have replaced PMD for an unrelated failure and that little quirk is still there very infrequently,so I just live with it.
    I have seen threads that others experience the same Phenomenon, I do not think it is a serious issue.
    Dave
    99 sub 2500, 326,000mi, 4:10, 265-75-16 rubber, remote Dtech fsd and turbo master from Heath Isspro pyrometer and boost gauge-Kennedy, 1.94 TDCO, 3" custom bent exh.
    07 Suburban,08 LMM, Allison 6 speed.
    Feb 2008
    Time to give this thread a bump. The matter is getting worse. Bouts of spastic reving repeatedly going on. It stops when I let my foot off the go pedal. Some days it's fine but others it becomes quite a rodeo. Any thoughts?
    Sold
    Remote PMD
    Feb 2012
    Pauline, SC
    Might need to get some contact cleaner and clean all the wire connections & the ground points before winter gets here....
    It does sound like a PMD symptom, might wiggle the harness around and see if you can make it rev while you are wiggling the wires, may be loose somewhere....
    1993 Chevy K3500
    like us on Facebook
    Ft. Wayne, In.
    The foot pedal is a potentiometer. Could it be that the "pot" is dirty and now intermittent? This could cause a intermittent reading of wide open, idle or anywhere in between.
    I've never looked at the schematic of the thing but some of the brands (probably all) use dual "pot" so that they can detect dirty segments of the "pot" and set a code.
    Hoping someone else like "DMav" or "More Power" can jump in here and comment.
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Dave
    Not the APP (pedal). It has 3 independent circuits. Any of the 3 failing will set the STS (Service Throttle Soon) lamp and code. 2 failing will set limp mode, and 3 failed won't respond at all. Even if only intermittent.
    Feb 2008
    I have no codes. What are the possibilities it is IP related? This is really weird. I have a remote pmd and a known good pmd still attached to the pump. I will plug in the one on the pump and see what happens.
    Sold
    Remote PMD
    Feb 2008
    It was cold this morning and the colder it gets the worse the situation becomes. Seems to resolve itself as it warms up. It was so bad this morning she finally went into limp mode. I pulled off the road and restarted it and all is well. I'm scratching my head.
    Sold
    Remote PMD
    Feb 2008
    I plugged in the original PMD on the IP and the situation seems to have resolved itself. I will repost in a week to give it a fair test. Supposed to snow here on Tuesday.
    Sold
    Remote PMD
    Feb 2008
    Problem fully resolved. It was the FSD. I don't think I heard of one going south with these particular symptoms. It was a Dtec remote mounted.
    Sold
    Remote PMD
    Hi Dave
    How long did the Dtech last?Months KM's?
    Any comparison to previous FSD's in longevity?
    Thanks Thomas
    Feb 2008
    It lasted less than two years. The Stanadyne on the pump is older than that and still works. However you can't make a decision based on one case. I will replace it with another Dtech and we shall see how it goes.
    Sold
    Remote PMD
