Thoroughbred Diesel is always adding new products. Our newest product is the Superchips iHawk. Thoroughbred Diesel is taking pre-orders for the iHawk 379505 with an expected ship date around the end of August 2012.
The Superchips iHawk is like a virtual test track ... at your fingertips! Capture data like a pit crew! Measure your ride, just like the pros! Monitor Your Driving Performance - Watch your Vehicle Like a Hawk.
Superchips iHawk LINQ 379505
aFe Power's new Glide Guard brings performance engineering to the protection of your differential. This glide guard is constructed out of durable 5/16" thick steel plating for maximum strength and styling to protect the differential from direct contact in severe off-road use. This unit installs over the stock AA14-9.25 differential cover or aFe 46-70041/46-70042 differential covers. The glide guard mounts directly to the differential housing and allows for a much smoother glide over obstacles forward and backwards.
Application: 03-11 Dodge 5.9L & 6.7L Cummins
aFe Power Glide Guard 46-70049
When additional horsepower and torque are added to your duramax, you run the risk of cracking the stock flexplate. Designed to handle up to 1500 ft/lbs of torque, the new Duramax Black Oxide coated flexplate is corrosion resistent to prevent hydrogen embrittlement, billet machined and precision balanced for ultimate strength. This flex plate is twice as thick as stock and has passed the stringent 29.3 SFI testing, making it legal for use in race sanctioning bodies specific to High Horsepower diesels. These units are a direct bolt-in and fit any OEM or aftermarket torque converter.
Application: 01-12 GM 6.6L Duramax Automatic Transmission
BD Duramax Black Flexplate 1041260
