Generally, the preferred spot for a sensor is in the manifold, just below the turbo. If you search for "boost gauge" (or similar) you'll get a TON of reading material that will help you. Select "6.5 forum" for better results with the search.
Does your intake have a black, plastic tube that connects into the intake rubber? If so, you really won't hear much whistle with that in there. Remove it and plug the hole.
Reason: clarification
