I seem to remember reading several posts about a wiring harness on the fender well chaffing on some kodiak models and weird lighting issues.
Might be worth a poke around the engine bay to look.....
1998 k2500
Thanks I'll check the harness out. I do have DLR's and I did make sure the Ebrake is off. I just don't have the low beams. It's wierd. I think maybe it's the high low switch in turn signal lever. I guess I have to pull the wheel and r&r it. Thanks
0000000
I've looked at the wiring diagram and what I see is that if you have DLRs you are getting power to the low beams. The low beams get there power through the DLR relay. It almost has to be a bad relay.
Denny
2018 GMC Denali HD 2500 L5P.
Ok, I had swapped out the reverse relay with the DRL relay. They both use the same relay. I wonder if they could both be bad?
0000000
Not likely. Back in the diagrams I go.
Denny
Thanks, I also tried using my Tech II but didn't have any luck.
0000000
Do you have High beams.
Denny
Can someone tell me the fix on this one?
Thanks
Anybody figure out the remedy on low beam problem ?
