Quote Originally Posted by SID6FIVE View Post
the few times I have seen this, the 5-pin relay for the headlights or low beams got switched somehow with a 4-pin relay...usually swapped with another relay next to it...weird things happen, much as you describe...
A pal of mine had the problem currently with his low beam he even tried doing the 4 pin relay swap, but still didn't work He just replaced the fuse and all went back to normal.
