Results 1 to 10 of 10
Thread: Cold Weather Operation
    Default Cold Weather Operation
    and the GM Diesels
    Updated for 2012: Operating a diesel engine during the cold winter months demands that all diesel fuel and electrical systems operate normally. Included here is list of precautionary measures and cold weather strategies that will help your diesel pickup operate reliably throughout the coming winter. If you're new to the GM diesel, the information found here should help to answer your questions as well as reduce any anxiety you might have about cold weather operation. It's really easier than you think.
    USDP's 2012 Dyno Day
    USDP's sixth annual Dyno Day was held this past June 2, 2012 here in Missoula Montana, and the crowd just keeps getting bigger each year. From morning till late afternoon, 3 dozen of the Big Three's diesel pickups rolled across the Mustang dyno rollers and kept everyone entertained.
    Jul 2003
    Allentown, PA
    Concerning the fuel cap... I had always thought that a fuel cap kept a constant vacuum on the fuel in the tank. I did not realize that, instead, it was designed to keep a slight pressure OR vacuum on the fuel. Thanks!
    Quote Originally Posted by DennisG01 View Post
    That's right! Every fall, we get a number of reports of engine running problems that can sometimes be attributed to a faulty vent in the fuel tank cap. When summer temperatures transition to fall there can be large temperature swings between the daytime highs and the overnight lows. This large swing causes the fuel in the tank to expand/contract more than at other times of the year, which can produce more pressure or vacuum in the fuel tank. The vented cap is supposed to deal with it.
    Combine a bad cap vent with a weak fuel filter seal or problem with a fuel line, and a fuel or air leak can result. Caps are cheap, but be sure if you do replace it to buy a genuine "diesel" fuel cap (preferably one from GM). A gas cap isn't vented at all or isn't vented the same (a gas engine powered vehicle uses a fuel vapor recycling system). Jim
    Maplesville, AL - Home Base
    Jim,
    In your Cold Weather Operation update that you posted a couple of weeks ago, you state that "2001 and newer Duramax equipped trucks came with a grill cover tucked away under the rear seat". Was this cover included with all Duramax trucks or only ones that were originally shipped to norther dealers?
    I'm asking because I have a the 2006 LBZ in my signature and if there is a cover under my rear seat I need another clue to find it. Now living in Alabama I certainly don't need it, but if it is there I would like to know it. You never know, since I'm retired I might go visit Mark up in the north country some day.
    Thanks Jim.
    Ed
    KM4STL
    Ed - that would be fun for sure, but you better hurry because we are headed for Seattle next spring...
    If the cover isn't there, it isn't there - they aren't hidden, just sitting in a plastic bag under the seat.
    They always seem to be missing when I buy trucks - I have purchased new on Ebay, from people in TDP that live in the south regions, and (lastly in desperation) over the counter at a GM dealer.
    The BEST reason to use these covers (beyond the obvious quicker warm-ups, better fuel economy, and moderated engine operating temps) ???
    They keep all the grit and sand and salt that covers the roads in these winter conditions OUT OF YOUR ENGINE BAY, and OUT OF YOUR COOLER STACK.
    Bugs eventually get wet from rain and break down with heat. It they get bad enough, you can easily use compressed air and water to flush them backwards out of your coolers.
    Grit, sand, and salt? That stuff does a lot more damage and is harder to remove from the fine slits of the coolers, in my observations.
    I use my covers anytime weather drops below 10F.
    Thanks Mark. My 2006 didn't have one, or the dealer "borrowed" it before I came along.
    10F? I can't tell you the last time it was that cold here. This past winter I don't recall it ever getting below 20F? Two years ago I remember a couple of nights in the 13F range. Now the local "fuzzy worm" weather forecasters down this way are predicting a much colder winter. We shall see. I do remember our last snow (other than just a few flakes) was in 1993.
    I just plug my truck in when it is going to get that cold.
    Ed
    KM4STL
    Dec 2006
    North Pole, Alaska
    My 05 has a Block heater, a small automated battery tender (only works when the batteries need a few amps, not full time) an oil pan heater, a transmission pan heater, and at -50 or worse she fires right up.
    The 99 has the same except that instead of the battery tender, it has two heating pads underneath it's Optima's to keep them warm and operating at max amperage. It's a toss up which system works best, because as long as either truck is given 1-2 hours of plug in time, they'll fire right up at -50.
    The 6.2 has 2 block heaters, battery warmers, and the oil pan pad. It's a stick so I don't warm the transmission on it, however, I've found I have to sometimes leave it in neutral when it's cold. At -50 the oil is so thick, if it's not in neutral, I have to put the T-case in neutral so I can let the clutch out. Which can also be a chore. I've had days where I had to drive around the block (luckily it's only got a few houses on it and little traffic) in first gear to get the fluid warm enough to move the shift lever. I always leave it in a gear I can use before shutdown now. (I usually back into my parking spots, and leave it in first, just in case)
    All three of my trucks have cardboard blocking the radiator, and the 6.2 has dual electric fans that are manually triggered. In the winter, the only time I use the fans is on big hill climbs while offroading in low gear. Once you're moving, even with the radiator blocked off, it doesn't need the fans to maintain 195.
    Concord, NC, USA
    Wow! Extreme stuff! I can't imagine 80 degrees below freezing. It just doesn't register to me.
    Mark Chapman DP member #653;
    1983 K2500 6.2 Suburban, 4" lift, 35" tires, ATS turbo, Banks exhaust/intake, pyrometer, tachometer;
    1986 K5 6.2 Blazer, 2" lift, 33" tires, Banks intake, pyrometer, tachometer
    1963 wife, one owner, average mileage for the age but in excellent shape, a keeper
    1992 daughter, low mileage, pretty, limited edition, but requires some money to maintain
    1995 son, sports model, very fast & peppy, time will tell on durability and maintenance costs
    "Grease is good"
    In the "for what it's worth" category, GM sent several Duramax prototypes to Fairbanks in late 1999 to be tested during the extreme cold of an AK winter.
    The factory-included "winter front", cold warmup/glow system programming and other mods resulted from their time spent there. At the time, the engineers I spoke with said getting the engine to warm up was a challenge because so much of the design and development of the engine had gone into ensuring it ran cool while towing heavy in the summertime desert heat. Jim
    Sep 2007
    Jax Florida
    Quote Originally Posted by Subzilla View Post
    I used to live in North Dakota, and while -50 is extreme late dec to early feb temps were generally below -30 with times of colder.
    93 GMC Sierra 2500
    6.5L TD Auto
