Results 1 to 15 of 15
Thread: Loss of power and runs rough
    Nov 2012
    taft, ca
    Default Loss of power and runs rough
    I bought a 04.5 Dmax about 5 months ago, sense then I've had very few problems with it. The problems consist of pulling to the right due to the idler and pitman arms and upper ball joint dismembering itself from control arm. Until recently, about a month ago i noticed that it doesn't pick up the way it when I first got it. I have replaced the fuel filter, that did no justice. So I assumed it had to be an injector problem but the truck is new to me, so I called the closest dealership and had them run the vin# to make sure all recalls had been taken care of on this particular truck: and the had. So the injectors were replaced due to the recall about 10 months prior to my purchasing it. Now I'm stumped, this is my first diesel so this is all new to me. I'm pretty mechanically inclined so doing the work myself isn't a problem, knowing where to go from here is.
    I'm running 4in Banks exhaust
    Banks cold air and intercooler
    Banks sixgun programmer
    32in Mckey Thompson MTZ tires
    My buddy put his basic code reader up to it and dispite the check engine light not being on it did through a few codes out. One was for coolant temp, one was a misfire in cylendar six, one just said comp.( which I just figured was due to the programmer ), and the last on just said EGR with no other discription.
    Does anyone have any suggestions? After all the other stuff Ive done to it I have just about depleted my savings, so cheapest but most efficient way possible.
    Welcome aboard. I am pretty sure that you'll find this to be the best truck you've ever owned.
    Unless you are experiencing knocking and/or white smoke visible in your exhaust (either at idle or under acceleration), or black smoke under acceleration (overfuel condition, lacking enough boost to burn fuel present) I'd say you are looking at a simple fuel or air supply problem. Since you've replaced the fuel filter, how about the air filter? Any chance of restriction or temporary collapsing of an air inlet tube during high demand/acceleration?
    The codes could be misleading since they may be from BEFORE the injectors were replaced. I'd take note of them, then clear them all and start again.
    If you are NOT seeing white or black exhaust smoke under any of the above conditions, no fuel rattle, and no oil dilution/making oil at the dipstick...
    Q1: Is it possible that there is a problem with the power adder, and you're not getting the additional fuel rate that you had grown used to?
    Q2: Could you have a leak at one of your aftermarket intercooler connections, and be leaking charge (boost) air?
    Keep checking in as you troubleshoot. I think you'll find the root cause of this one to be a simple one.
    Nov 2012
    taft, ca
    Thank you for your prompt response.
    I check the connection at the intercooler and found them to be secure and leak free. There is no sign of any color smoke coming from the exhaust, and when the problem first occurred I was in the middle of passing about five diesel trucks and the sixgun programmer was turned up to 6. The check engine light did appear as well as the loss of power. I pull over, turned the truck off and reset the programmer by unplugging it for about 30 sec. and plugged it back in, and the truck seemed to be back to normal, for a couple weeks anyways. Then began the gradual depletion of everything. Although the check engine light went off I still borrowed the OBDll code reader and those codes popped up so I cleared them and waited a few days to read it again. The codes came back and have been there ever sense. Any and all suggestion or ideas are appreciated and welcome. Thank you for your time.
    If the EGR isn't blocked and disabled, it's probably fouled. The excess soot can also foul the vane position servo. Running the Six Gun on level 6 is not a good idea, especially at highway speeds or with a load. If your tranny is stock, you'll be shopping for new very soon. Level 6 also expedites EGR and servo fouling, moreso than lower levels.
    Nov 2012
    taft, ca
    Thanks for the info about the six gun. I'm not really too fond of not knowing or being able to monitor or even see the parameters. It didn't come with gauges or a digital screen, just the component and a dial. I never really turned it up past 4 except at night while passing due to the difficulty judging how far away the car in the other lane is.
    Now, that being said, my next hypothesis is the head gasket could possibly be blown or maybe leaking by. My reason for this conclusion is: while going over the inlet and outlet to the intercooler I noticed that the coolant hoes on the driver side was slightly collapsed and the coolant level was a little low(less than 2qrts.) So it made me wounder where it went. Upon checking the oil level (which was full), it seemed like it didn't want to stay on the dipstick, and the oil pressure seems to be a little high.
    Any thoughts? And what is normal operating oil pressure? Isn't there supposed to be discolored exhaust if the head gasket is blown?
    That's a risky proposition, a power programmer and no gages.
    Head gasket? Difficult to say. Any one of the symptoms you list don't indicate that, in themselves. A collapsed coolant hose is more likely a failed recovery tank cap. "Slightly" collapsed may be normal. Coolant loss can also be caused by a bad cap. All of it depends on how much loss, and under what conditions. If it's very slight, you may not notice foggy exhaust (steam), or the associated odor. Start the engine after cooling overnight, and check the upper coolant hose after a couple minutes idling (as soon as the temp gage begins to move, but not hot). If it gets very hard, you have a bad gasket. If it seems normal (neutral pressure), then it's less likely.
    Oil pressure depends on other factors. Cold idle pressure should be 60-80 PSI. Hot idle should be 20-40. It can be higher/lower, depending on the oil brand, grade, and other conditions. If you have coolant in the oil, it will usually have no trouble sticking to the dipstick, and will be cloudy or milky. To confirm, drain some oil after the engine cools overnight. Most of the water, or water saturated oil, will settle to the drain.
    Nov 2012
    taft, ca
    I appreciate all your help,
    The oil on the dipstick is not milky nor does it look to me like the is any foreign liquid present, but the dipstick is stainless and for some reason (it's probably been reading this way sense I acquired the truck) I just noticed the oil doesn't want to really adhere to end of the stick except for where the reading marks are.(the end is round and forms an point)
    Anyways, the level of the coolant was about an inch under the "FULL COLD" mark but not as low as where it drops down to go into the radiator. As for the hose, it still had plenty of room for me to squeeze it and make the water go back into the fill tank.
    To better explain, the truck was my daily driver. It went back and forth to work (about 8 miles a day) and to pick up the kids 3 to 4 times a week (round trip approximately 110 miles 3 to4 times a week). When I noticed a drastic decrease in performance I parked and have driven it maybe twice in a months time, for no more than a mile or two either time.
    Now I have cleaned the MAF sensor, just to rule it out as a suspect, it seems to have developed a slight tick but it doesn't go in rhythm with the motor. It sounds like its coming from the a/c compressor. Any other ideas or suggestions before I begin dismantling things to replace the gaskets?, which is the culprit in my personal opinion.
    Nov 2012
    taft, ca
    this what I'm working with. sorry they aren't that clear its dark and the battery on my phone is dieing so the flash doesn't work.
    Your oil checking sounds normal. Mine has always been that way. As long as you can check the level by the notches, it's normal. I've never noticed oil adhering to the "bulb" or cable part of the dipstick. As long as the oil you are seeing is normal, nothing to worry about there.
    Your coolant level may or may not be normal. It will decrease over time, normally. The description of the hose sounds normal, as well. If it isn't sucking down flat, it isn't significant. A little is normal, after a cool-down. Not a reason to suspect head gaskets.
    If the DTC's are persistent, you really need to read/report them better. The actual code numbers would be much more helpful.
    I'm not sure what you are trying to show/say with the pics. In any case, any time you have a running issue, and you are using a power module, the first thing you should do is remove/disconnect the module. Get it out of the loop so the system can be properly diagnosed. Often, the problem is the module, or as a direct result of using it (such as a fouled EGR). Now, in CA, if you have emission system codes, you can't pass the smog inspection. You have to get it clear, one way or another.
    Maplesville, AL - Home Base
    One more reason I have no desire to ever go back to California and definitely will never live there.
    Ed
    KM4STL
    When in doubt, disconnect aftermarket boxes (not a fan of hardware type mods anyhow) and drive stock. As Mav stated we need DTC numbers rather than vague descriptions.
    Check teh MAF sensor for oil and dirt. Better yet if you have the stock intake reinstall.
    Quote Originally Posted by EdHale View Post
    It isn't all that bad. This applies to all vehicles, Diesel or gas. If the check engine light is on, they don't pass. Diesels are easy, otherwise. If they don't smoke excessively, and have the OEM emission equipment installed (visual inspection), they pass. CA just started inspecting Diesels a couple years ago. Many other states have been doing it for many years/decades, with much more strict requirements. I don't like messing with it every 2 years, but I'm surprised it's taken them this long to start inspecting.
    Nov 2012
    taft, ca
    Thanks you guys, I really appreciate the advice.
    I think I have plugged that stupid ODB2 code reader into the truck about 6 or 7 times and it doesn't seem to through out any #'s just words. I don't know how else to describe the readings, and as for the pictures; they were just to show the aftermarket components that have been install. I was hoping that they would make diagnosing the problem a little easier.
    Last edited by dmax_lineman; 11-20-2012 at 20:20. Reason: forgot to reply to one of the questions ask in the last post.
    Nov 2012
    taft, ca
    Talking
    I HAVE FIGURED IT OUT!!!!!
    INNOVA ODB2 Code reader has that is very descriptive. Without the programmer plugged in, the trouble codes are still in the computer stored under HISTORY. But the regular $60-$80 code reader wont differentiate between new and old codes it just give out what it finds. So if all previous codes weren't properly removed the will keep showing until they are, even if you have already fixed the problem.
    Anyways, the programmer's settings are not accurate and it isn't telling the fuel rail pressure to increase when it needs to. But on the other hand it was telling everything else to increase in volume, and the gear ratio is way off. So it was making the trany long before it was supposed to(the RPM's weren't high enough to make it into the next gear) so it wouldn't shift. The check engine light would appear and the trany would go into whats called SAFE MODE so to speak. It won't shift or let the engine over rev until the problem has been removed or taken care of. So basically the programmer is to blame. Does anyone know if it can be reset to work properly? If so, what do I need to do so? If not, (my whole system is Banks so I'd like to keep it that way) does anyone know which Banks programmer is going to work best with my truck and help maintain relatively fair fuel economy?
    THANKS FOR YOUR TIME AND EFFORT,
    dmax_lineman
    Quote Originally Posted by dmax_lineman View Post
    dmax_lineman
    Same info gets same response:
