AKMark:
The easiest way to tell if you can just do a flash of TCM for sixth is to look on the drivers side of the trans and if you see the NSBU there then it can't be done. On those transmission that can be done the NSBU is internal.
Denny
AKMark:
Denny
2018 GMC Denali HD 2500 L5P.
Cool that it worked for you. My 05 has the external NSBU, so no 6-speed.
No worries, just figured I'd ask.
Inspector,
Will changing the Vin in the ECM cause any problems when getting a smog check?
What D Max said.
Denny
In the earlier Duramaxs you can change the valve body and TCM to convert to a six speed. I've done this to mine some time ago. I just returned from a 2000 mile towing trip, and feel in those circumstances the 6th gear didn't do me any good. I towed mostly in 5th gear.
2004 G.M.C. LLY CC D/A sb 4wd Summit White, ATS Duals, BD X-monitor, BD Exhaust Brake, Snugtop shell, 45 gal. Transferflow fuel tank, AFE stage II
2004 TDI Jetta GLS S/W
2005 TDI Passat GLS S/W
2020 GMC Denali 2500HD
This is interesting. Haven't read anything about it in a long time, and never have read, before, a report from anyone who had done it.
What is the size and weight of your trailer? And, is it still a $2000~ proposition?
