Originally Posted by
Kennedy
OK guys stop and take a deep breath here. Dennis has a Medium duty vehicle built as a 6 speed but calibrated as a 5 speed. The pickups are either 5 or 6 speeds. The 01-05 can be converted to 6 speed by using a custom programmed TCM (proprietary software using unreleased stolen? calibrations from Allison) and a modified valve body.
I did this to my 05 years back. I don't really think it gained me much in terms of MPG, but it does make things quieter. After driving a 6 speed truck and then switching to a 5 speed it just seems "busy" with too much engine speed at cruise.
P.S. the pre-Bosch ECM trucks do not hold 6th as well as the post. Be it superior TQ or simply programming differences, the LBZ up series holds 6th much better and responds much better to increasing loads.
I believe we already knew this. I actually can hold six gear fairly well. I chose not to as a truck driver equipment operator, I don't believe in pulling them hard at low rpms. Also with a 55 mph speed limit, unless your on a flat surface its too high geared. I experimented both ways 5th or 6th and depending on the terrain and the wind determined which gear I cruised in.
You might check with Suncoast and ask them if they stole allison programming. I do not know. I expect a person could and has said the same thing about headlight harnesses and other various items that other companies developed.
2004 G.M.C. LLY CC D/A sb 4wd Summit White, ATS Duals, BD X-monitor, BD Exhaust Brake, Snugtop shell, 45 gal. Transferflow fuel tank, AFE stage II
2004 TDI Jetta GLS S/W
2005 TDI Passat GLS S/W
2020 GMC Denali 2500HD
