I didn't see that part number listed on Heath's site, but...
With the way you are using your truck (and the relatively mild temperatures), are you sure you need to do this modification? Maybe you just need to clean out the fins of the radiator and other coolers? Possibly pull the radiator and give it a good flush, too.
