Hi cjones
If it was my truck i would be inclined to not flush if you know something has been added to seal a leak.Flushing may produce that leak,so be prepared to have to fix something.
You can test the ph leavel in the coolant and adjust that with additives.
I have a Mack truck with a V8 500 in it,one of the heads has an edge the salt on the road can get at the gasket,it started leaking to the outside,anyhow we are way off the beaten track up here,and i was advised to try some bars leak in it before tearing off the head by a mechanic at a shop that did Mack work.
Never had it leak again.
Drive it,get some roadside asistance for towing if you venture far from home.
If you suspect problems start saving for a replacement.
Good Luck
Thomas
