Thread: Glow plug relay
    Mar 2010
    Default Glow plug relay
    Does anyone know what i need for resistance and/or voltage to fully test a glow plug relay . I think mine may be on its way out .
    Thanks Brian
    1994 GMC 2500 6.5LTD 4wd
    Marine injectors and built 4911 pump to run veggie oil
    1981 Toyota 22L Diesel Pickup
    Check your fusible links, first. If they're swollen, hardened/brittle or cracked, they may be bad, or weak (low conductivity). Make sure all the connections, including all grounds, are clean and tight. Otherwise....
    Batt+ in, Batt+ out. Be careful to not overcomplicate it. The GP circuit demand is about 100 amps. The relay isn't expensive, unless you buy it at the dealer.
    Mar 2010
    ok ive got a few extra ones i just wanted to check and make sure there working ok before i swap one out . Thanks
