Results 1 to 8 of 8
Thread: Kennedy Diesel lift pump
    Default Kennedy Diesel lift pump
    Never installed - new in box. Label on pump says 'PO' date of 1/11, and 'D5 Strong DU 8-24VDC'. Motor housing is black, machined pump housing is black.
    Compare to:
    http://www.kennedydiesel.com/categor...bCategory2=126
    Best offer. PayPal payment preferred.
    Default Allison TCM
    End Model P/N #15183963
    Best offer - PayPal payment preferred.
    Default Lb7 ecm '01-'04
    Spare ECM from 2002 K2500. I will guarantee this as a good core you can exchange or retain as a backup if you flash yours with a performance tune.
    SERV. NO. 09388505, HDW NO. 09355100
    $300 obo - PayPal preferred.
    Default Maybe.
    Hi Mark, doing up a mechanically injected 6.5 going into a Toyota. If the standard mech pump on a 93 engine puts out 4 psi then this pump matches that. Only worried about the 24VDC. Checked the Kennedy website but didn't say 12v or 24v. Toyota is 12V. Thanks, Colin.
    It isn't "24V DC". It will operate between 8V and 24V DC. Your 12V system is compatible.
    Default new lift pump, ecm, tcm
    ...cleaning the garage! Make me an offer for all three...best takes the lot.
    Sep 2013
    Kentucky
    Default Pumps
    Still have them?
    Dec 2006
    North Pole, Alaska
    I can send you $150 for the pump shipped in a flat rate box to Alaska!
