DB2, naw...
those parts are hard to find. The Throttle cable and petal are discontinued and not available. Cruise cable same deal...
You have a wiring fault.
Shoot, there is a 1996 wiring harness on ebay that you could throw at it way cheaper than converting to DB2.
To me it seems like a broken ground somewhere IN the harness.
An alldata DIY membership will grant you access to all the wiring diagrams for a 1996 Burb, then you could test for continuity on all the wires and pins. It'll take awhile, I know, did the engine test stand thing with a DS4 OBD-I, they're simple. I'd still like to do a OBD-II on just to say I've done it...
At least with your 1996 it's not a theft-deterrent issue like it could be on a 1997+.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
