Hi
Are you putting the 6.5 into the 83?
If yes then you can use the mechanical pump.
If you want to use the mechanical pump in the 96,then a few other things need to be answered,like is the 96 auto or manual.
Give us a little more info on what you are doing and someone will give you the info you are looking for.
Thomas
