Results 1 to 14 of 14
Thread: fuel color question
    Dec 2000
    Hawaii/Arizona
    I agree 100% with John. I stopped using bio about four years ago because it seemed to have less power than standard diesel, cost more and it provided less MPG. I check my fuel mileage every tank full when I am pulling my 5th wheel and there is absolutely no doubt that bio is a bad deal. I generally drop at least two MPG with bio.
    *2007 Pontiac Solstice.
    Apr 2009
    Sheridan, Oregon
    That was a few years ago, now. For some reason I want to say it was B-20 or something like that. Anyways, I won't use it at all now. I know someone that has used B-100 in his burb and I have his old injection pump in the garage with sensors gone bad in it. And I have seen first hand what B-100 does to the injectors and such after not that long of being used.
    2004 Chevy K3500 CCLB DRW Duramax. Stock.
    1992 Sea Ray 300DA. 30 plus foot Express Cruiser on a trailer. 13,500# boat and trailer and 69' of combined length rolling. Over length/width permitted load.
    SOLD-95 GMC K2500 SLE 6.5L TD, Relocated PMD to bumper #9 res., Custom Lowes special induction tube, Triple gauges on the pillar EGT, Trans, Boost, High Idle Mod, TCC-Lock up Mod, Custom Back up camera, DIY Manual Wastegate Controller, 4" from down tube to 5" stacks, Vac Pump Removed,2007 wheels, WMI by Cooling Mist 8gph @3psi 11gph on demand
    Apr 2004
    Ottawa, Ontario
    Quote Originally Posted by jhornsby3 View Post
    90% of the issues with B100 is the quality. ASTM standard B100 actually extends the life of the entire system. The electronic DS4s had an issue with fuel clarity and caused some wonky issues with the sensors depending on what the original feedstock was. Soy based was darker and the Canola based fuel actually has a red tinge to it. The optical sensors at times got confused.
    Guaranteed, the injector issues were water and or filter related. Again if the methanol was not washed out completely, the fuel will suck up water like a sponge and you want at least 5 micron or better filters.
    I made my own fuel for about 4 years and never had an issue with 3 vehicles, 2 6.2s with mechanical pumps and an aging Mercedes 5 cylinder. Even extended the life of a fubarred db2 for another 30,000 miles by using B100. But than again, I was very anal about fuel quality and making sure the process went to completion, and all batches were carefully de-meth'd and washed. Pain in the neck, but could produce about 3,000 gals a year (also fed my oil furnace and hot water heater with the stuff) for about 1/4 of the cost of #2.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    Sep 2007
    Jax Florida
    Quote Originally Posted by convert2diesel View Post
    Bill
    Yes this is very true if they wanted to commercially use bio they make sure the quality is perfect it would replace #2 which would be bad for oil...
    93 GMC Sierra 2500
    6.5L TD 5 spd Manual trans Sold
    97 Chevy Silverado CrewCab K3500 Dually
    6.5L TD Auto
