Anybody have a source for theses I My fingers are starting to bleed searching the net for them. I can find end caps but not the corners.
http://
http://
It covers the horizontal and vertical corner of the wiper seals on my slide on my fifth wheel. Have the same corners on the trim around the shower too.
Maybe RvTech will chime in soon. . . .
http://
You could call your trailer manufacturer. They would probably know where to get the part you need. I've done that in the past for my 5th wheel and always had success.
CareyK
Sorry, just now saw this post.
I haven't seen those in a while. What kind of rig? Year, make, model?
1995 AutoMate 36ft Fiver
I can find the end caps in metal and plastic, just no corners. Tried Bill Wyrick today just got voice mail.
Tracked down the axels, 6k A&H new in 99 along with frame. Been living in it since we got it end of 99 and trying to get it road ready since we both retired.
gross max weight is 13200 so with 6k axels that would leave 3200 for pin weight. a little closer to max than I would like but will get it weighed here in a few weeks. Plan on being out of California by June one.
And thanks for the reply.
I've had no luck finding that corner trim. I would suggest fabricating something out of aluminum or steel.
