HI everyone,
My 94 6.5 has been starting up, and then stalling a few seconds later. After 2-3 15 second cranks on the starter, it will fire up, then run rough for about 15- 20 seconds, before clearing out. It will run for hours with no problem, if I shut it off, it will start right up if it's hot. After sitting for 15-30 minutes, it's back to the same problem. I have Replaced the Pmd and moved it away from the manifold. I did replace the lift pump and fuel line a few years ago. I orignally had a stalling while driving problem, and moved the Pmd thus solving that issue. Recently it started the latest issue, so I just replaced the Pmd, it ran a lot smoother but still had the start/stall issue. Any input would be apreciated.
Thank you
