1999 Sub 4x4 2500 LS
My tank started a slow leak so i drained it and removed it to find it was quite rusted around the bottom areas where it was covered by the plastic shield. i am guessing that between the plastic and heavy metal shield the moisture has nowhere to go so it eats away at the steel tank until it starts leaking!
My tank did not appear to be zinc plated or painted that well, given the amount of rust on it.
Does anyone have a recommendation of what type of tank is best without getting yourself in trouble for naming a vendor?
One vendor had free S&H BUT did say that because it is such a big tank that you should expect a few small dents and that that was OK!
Another vendor said there tank was zinc or galvanized plated.
A well known retail auto parts chain in the S Jersey area said there tank was painted.
Has anyone replaced a tank within the last few years with any advice on this?
I was advised to use the same pick up / sender unit but the feed and return lines where so rusted it decided it was not worth the risk of having one of the lines rust out and then having to drop the tank again! So i will be buying a new sender unit also...more $$$ but what you gona do.
I figure i am saving at least $3-400.00 in labor, yes?
Is there anything worth doing when the tank is out that can be done when it is installed?
I was impressed with the heavy gauge steel used to protect the outside of the tank in my Suburban...
I am sure it is a option on Suburban's or do they all come with this steel shield?
Of course it had to start the slow leak after i toped it off with 42 Gals of fuel!
I siphoned out 90% then dropped it got a dry wall screw to tap a hole in it to drain out the rest.
I know diesel is much less flammable than gas but figured a sharp drywall screw was the safest way to punch a hole in the rusted tank to drain out the rest of the fuel.
I stored the fuel in a 55 gal plastic drum i found a work. It looked unused and very clean in side and the caps where on tight.
if i had it to do over again i would hot wire the lift pump an run a line from the pump to the storage tank.
Any advice on what tank to buy and other pointers is appreciated.
