I have 72lbs of pressure. As long as you currently have flow, I can't imagine it being a problem as the water is just going to go right through - there's no blockages to build pressure.
Flush it first with the garden hose to take care of 99% of the flushing, then flush the "bad" water out with air to get rid of most of it. I seem to remember just blowing it out by mouth. Then pour AF through - just keep one end higher than the other and gravity can do the work for you (use mouth/air tank pressure to help if you want).
