Turbo Wastegate Vacuum Actuator Bolts
I went to replace my WG actuator after getting a P0236 code and managed to lose both bolts that hold it on to the turbo. They were pretty rusty in the first place and was going to replace them but now I don't have anything to compare new ones with.
I also looked at every diagram of the actuator I could find but none of them include part numbers for the bolts or even show them at all.
Does anyone know what size they are? I know many of you will say switch to a mechanical one - and I plan to with a Heath PCM. Problem is, I don't have time to wait due to camping plans, plus the money is a little tight. I'm also thinking of getting a different truck (Powerstroke maybe) that's better equipped to handle a 11k pound trailer.
Anyway, if anyone knows what size those are I'd really appreciate you sharing the secret with me! Thanks.
1998 Chevrolet K3500 Ext Cab DRW
6.5L Turbo Diesel VIN F
HD Cooling System Duramax Upgrade
4" Diamond Eye Exhaust w/ Muffler Delete
Custom Air Intake
All LED Lighting
Onboard Air System w/ Train Horn
- You may not post replies
- You may not edit your posts
Forum Rules
