Results 1 to 13 of 13
Thread: Lost power?
    May 2015
    Sunset texas
    Default Lost power?
    Ok so I put 4inch exhaust on my 6.2 I had a bunch of problems with it not starting after that I finally got in running sounds good but iv lost alot of power before it had a lot of go I could get it up to 100 pretty quick and burn the tires off now I do good to get it up to 50 and it won't even spin out on dirt any ideas on this
    Did you upgrade the muffler bearings?
    You might also consider changing the fuel filter.
    May 2015
    Sunset texas
    Haha ha ha filters are new
    Feb 2003
    Grand Rapids MN 55744
    still really sounds like you are not getting enough fuel.
    When you step on it does make some smoke?
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    May 2015
    Sunset texas
    Yes sir it black smokes I thought about turning it up and see what happens
    Lubbock TX, USA
    what's this in?
    Please fill out your signature with your truck, year, make, model.
    Do you have an EGR engine (vin C)?
    Do not turn up the fuel, it sounds like you have plenty already with the black smoke comment. You may have an EGR valve trying to open causing your lack of power and creating black smoke.
    J
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    May 2015
    Sunset texas
    It's a 82 chevy truck 4x4 6.2
    Feb 2003
    Don't turn up the fuel.
    As stated above, is your truck an EGR engine? Can you tell us what it looks like in the intake when the air cleaner is removed? Does it have a "dohicky" mounted inside the intake or is it just wide open?
    Does your driver side exhaust manifold have a restrictor valve in it? This would be right at the outlet of the manifold.
    May 2015
    Sunset texas
    Yes it has the egr valve in the intake and yes it has the dohicky on the manifold
    Feb 2003
    Howdy
    Do a search on this page for "remove egr"
    It will pop up some good threads.
    A good one right at the top is something like "J code worth it?"
    This will help explain what we are talking about and how it can limit performance.
    Just out of curiosity....do you know what gears you have? None of my trucks will easily hit 100.
    May 2015
    Sunset texas
    I'm not sure about gears but before it would haul some ass and the vacuum on the egr valve that go's to the little box thing with coper wire in it broke free from whatever it's supposed to be mounted to and u can see the wire on the in side of it could that be it cause it's not working I looked up what it's supposed to do and it's not doing it
    May 2015
    Sunset texas
    so can i just do a erg delete like i would on a gas engine
    Lubbock TX, USA
    I'd replace the intake manifold with a non-egr version. As a test you can disable the EGR by plugging the hose going to the EGR valve.
    search for uniquediesel, they have J code intakes.
    J
