Thread: Harmonic balancer(s)
    Nov 2011
    Calgary, Alberta
    Default Harmonic balancer(s)
    I an going to replace my Harmonic balancer but it appears the pulley for the serpentine belt is also a harmonic balancer. Should i be replacing them both?
    Welcome to the Forums!
    The pulley is dampened, but it's not a "harmonic balancer". It aides isolation of the harsh Diesel combustion pulses to the accessories. It should replaced at least as often as the balancer, typically more often. If the rubber is cracked, hard, or missing, it should be replaced, in any case. Once they fail, in any way, it isn't long before it starts to sound like a bad rod-knock, or worse, and can cause damage to the belt-driven accessories.
    Sep 2006
    Brooker, FL
    Replace the pulley! I didn't on mine, and the hammering eventually damaged the tensioner. I got the Fluidampr so I don't have to mess with the damper anymore.
