Results 1 to 2 of 2
Thread: allison fluid cooling lines 2001
    Default allison fluid cooling lines 2001
    Iam sure many have.... replacing the cooling lines difficult job? looks tight not much clearence to slip the lines foward. Any one with feed back. Thanks. Mike.
    The lines are no more difficult to R/R than any others. If the old lines are not reusable, you can simply cut them to make removal more simple. The new lines can be maneuvered into position without too much difficulty. Make a note of clearances and clamps, and install the same. Some replacement lines appear to be closer to the exhaust pipe, which is easily remedied with a little "tweak". Just make sure the lines are square with the tranny and cooler connectors, and it will be fine. If the line-ends are stressed, they will leak prematurely, if not immediately.
