Results 1 to 12 of 12
Thread: Having issues
    Oct 2015
    Sylvia,ks
    Question Having issues
    Ok I bought my 96 and it didn't start I messed with is and eventually changed the ignition switch and it fired right up made it 3 blocks and died.
    Towed it back home and messed with it the next day pulled codes said optic pickup in pump was fried so I changed the ip no fuel still to injectors
    So changed pmd again with 6 foot extention still no start
    Checked all of the grounds again and cleaned again just on safe side checked all wiring not finding anything noticeable wrong pulled all plugs apart and cleaned
    It is not kicking any codes and still will not fire getting very irritated any ideas what it might be I've been wondering if it might be the computer have changed everything else
    94 excab 3500 2 wheel drive 6.5 auto 4 in exhaust and chip
    96 reg cab 2500 4x4 6.5 5 speed 4 in exhaust
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    How long had the truck sat before you attempted to start?
    What symptoms did it have before this issue?
    Check the OPS sensor and all related connections.
    Verify that the starting system is in 100% condition
    Verify that fuel is able to get to the IP:
    -- check at the injectors
    -- check at the fuel manager/filter
    -- check the Lift pump
    -- check the fuel lines
    -- check the fuel tank and pickup in the tank
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Oct 2015
    Sylvia,ks
    It had sat for about 3 months
    Pryor to ignition switch going out my friend drove it every day to work
    Have checked all of that even put on new fuel tank (old one had a Crack) that was Pryor to changing switch so truck had run for about 30 min before it just died
    The thing cranks over like a dream no fuel to the injectors
    Be sure the fuel filter is clean (replace)
    You have replaced the IP so all the fuel lines are dry from the IP to the injectors
    Air in everything.
    Be sure the lift pump is sending fuel to the filter and on to the IP
    Remove the fuel feed hose on top of the IP
    Get the lift pump operating and air free fuel to the IP.
    Connect fuel line to IP
    Remove glow plugs "makes it easy to spin engine"
    Spin engine until fuel mist blows out glow plug holes.
    This should not take more than 30 seconds
    This technique makes it easy on the batteries and the starter.
    Also the IP is not having to fight compression to clear the air from injectors/ lines
    Make sure that when the key is turned on that the fuel shut off on top of the IP goes CLICK
    Was this a new IP or ????
    Get fuel to IP
    Remove plugs
    Spin until fuel blows out
    Replace plugs
    Glow
    Start
    Keep us in the loop
    Good luck
    Missy
    Oct 2015
    Sylvia,ks
    Air in everything.
    Get fuel to IP
    Remove plugs
    Replace plugs
    Glow
    Start
    Keep us in the loop
    Good luck
    Missy
    Thanks Missy
    It was air locked thought I had got all of the air out of it but I guess not
    It is running now after I fix a water leak that I just noticed it had the hard way heater hose fitting coming out of water cross over broke off and shot anti freeze everywhere (not any fun)
    So to fix it tomorrow and take information a driveway see how it runs thanks for all of the help guys I'll let you know how it runs
    May 2009
    North east/central Illinois
    Robyn is SOOOO wonderful. I think she has helped me more than anybody on all the forums
    98 GMC Suburban 2500 6.5 4x4 260,000 mi, Fluidamper, remote PMD, FS2500
    96 GMC 6.5 Suburban 1500 4x4 320,000 mi; Fluidamper, remote PMD, Amsoil bypass, K47 air filter
    95 Tahoe 2 door 4x4 6.5 320,000 mi; Fluidamper, Amsoil bypass filter, remote PMD, K47 air filter
    1989 GMC Sierra 2500 2wd 5 spd get-rag trans 800,000 mi.
    95 Chevy 2500 xtra-cab 2wd 6.5 190,000 miles,
    1994 chev K3500, FS2500 bypass filter, remote PMD, K47 air filter 290,000 miles
    2006 Jeep Liberty CRD 160,000 mi. 10-21-2015
    91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.
    Oct 2015
    Sylvia,ks
    Well I got water leak fixed and have had time to mess with it all weekend.
    It seems to run pretty good I think pump timing is a little to advanced (it pings while idling) but it's not kicking any codes so gonna retard the timing some and see how she does
    Other than that not any complaints for a $900 pickup I'll try and post some pics of it in a couple days
    May 2009
    A $900 truck is what we are looking for.
    My son needs anew engine for his truck. He took it to a shop to have the starter changed and they did not install the starter brace. They broke the block at the first hit of the key.
    Then they jacked him around and he had to lawyer up. But he didn't get enough for a new engine installed
    Oct 2015
    Sylvia,ks
    I run across these things all the time a little to nothing my uncle has been trying to sell me a 93 1 ton dually 2 wheel ex.cab that needs an engine it has the nv4500 5 speed in it also
    May 2009
    If you stumble across something we would be interested, I sure would appreciate a heads up. I've missed a couple. My son lives in Minneapolis and I live in Central Illinois. We are not afraid to take a ride for a cheap engine. We'd prefer a whole vehicle so we know the engine is what is claimed.
    Oct 2015
    Sylvia,ks
    Jrsavoie if your looking for an engine I'll ask my dad today and see if he knows where another one is.
    He just bought one for a 95 1 ton 4x4 that we are putting together to sell I'll ask him how much he gave for it and see if the guy has another one
    May 2009
    I appreciate it.
    My son's truck is at my house in Illinois now. We would be willing to travel for a good low mileage engine.
    I would prefer to buy something I can here run. We got burnt twice on engines that people said were good when they pulled them.
