Howdy
The 6.2 should swap just fine. actually the new one will have a serp belt set up that will be better than your V-belts. Both engines should have a vac pump. The new one might have a belt driven pump but Im not sure. Everything on the new 6.2 is mechanical. I think the only thing the computer is for was the transmission. The engine should run by itself with little trouble. You will have to swap the transmission controller on the side of the IP on your old engine and set it up for the new pump.
The other option is just swap out the long block and retain all the old accessories.
Good luck!
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
