HF has a viton seal kit for their pressure water pumps (Less than $100). Used these pumps for my bio-diesel operation. Output volume may be too high for what you intend to use it for.
How much oil will you be transferring at a time? I built a transmission/engine oil exchange system that used two 10 gal translucent HDPE tanks (so I could see the oil level) and hooked up a $150 HF vacuum pump @5 inches vacuum for sucking out the oil and my compressor @5PSI on the other to transfer the new stuff.
If memory serves, total cost was less than $200 bucks and could do a tranny oil change in under 1/2 hour.
Bill
