Crickets.......
I got nothing man!
Sorry!
Dave
Crickets.......
I got nothing man!
Sorry!
Dave
Dave, N9LOV
Member #242
Dave's Diesels:
'97 2 Dr Tahoe, Intercooled,
Kennedy ECM, 4" Exhaust
'02 GMC
Had to go back and dig this one up out of the dregs.
Found out some things about the Kodiak. First, the Saginaw steering gear in the Kodiak (that I have) is not adjustable.
Since it's a known factor, now that I've put about 7K on it, I've decided to do something about the handling. To date, that includes ordering up an HD steering stabilizer, a set of Sumo Springs for the front-end, that replace the jounce bumpers, a stabilizer bar for the front, a set of Air Ride bags for the rear, and a rear track bar. Still to be added at some future time, are Koni's, or Bilsteins, all around, an additional stabilizer bar for the rear, and a track bar for the front. Any advice about the Koni vs. Bilsteins?
So far, the air bags for the rear are the only thing to arrive, and I'm having a great time installing them. Only taking me about 4X the time it would take someone that is 1/4'th my age! The fact that the bags are built to fit either a medium-duty Ford or Chevy, is one of the hold-ups. The hole pattern for the main bracket is, indeed, the same. But, the bolts (for the jounce bumpers) that need to be removed to make room for the bag brackets, are 1/2 inch rivets on a Chevy! All well located to deliberately frustrate the installer. Drill, grind, chisel, till I'm blue in the face. And, to think that there was a time when I actually thought I enjoyed such things.
Ah, well, still anxious to find out if the handling gets better. Couple of weeks till Texas time.
Dick,
Sorry we're "No value added" here with this issue...
Keep us in the loop though...and have a safe trip down south!
Dave
Dave, N9LOV
Member #242
Dave's Diesels:
'02 GMC
Too bad that there aren't more medium duty GM's out there. I think that over all, I'm going to like the Seneca. It's a pretty much "high end" and heavy duty unit, for a class "C".
The last few days of crawling around under this monster has brought out a new familiarity with every muscle and pressure-spot in this old body! The MH sits on a concrete slab, and the creeper is just 3" of less clearance that I can't afford. So, I deal with the bruises and gouges. Removing 8 half-inch diameter rivets from flat on your back and offset to negate any direct action from a drill, or grinder, just makes life really interesting. Thank goodness that both snubber mounts are on the ground and both air bag assemblies are sitting on top of the springs, with the bolts all in. Anything else that's left to be done, is bound to be a cakewalk, compared to what I've recently endured. That includes one left thumb nail being cracked, across the width, except for a scant 1/8", and still oozing blood, though the thumping, with each heartbeat has stopped. I simply said SSPP, sucking air through my teeth. Yep, that was what I said.
Dick,
I'm not familiar with this "SSPP" form of profanity....
I consider myself a "Master-Tech" in the Automotive Profanity category!
Sorry to hear about your thumb though I'm glad you're over the hump.
d
Dave, N9LOV
Member #242
Dave's Diesels:
'02 GMC
SSPP is a deliberate misspelling of the Worlds most used, usable and appropriate word for almost any occasion, (also most any object, or substance) good, or bad. Quite honestly, SSPP is a shortened version of what I've been doing for almost 78 years, now, when I get injured. A long SSSSSSSSSS (sucking air through my teeth), and finishing up by slamming my lips together (P), and, with enough air in my lungs to expel that handy expletive with much more gusto. Within seconds, one just must pick up the damned hammer, ignore the shaking, throbbing, digit, and "get right back on the horse". You crawl out from under the MH immediately, and you probably won't go back there for at least a day. I assume that Y'all have been there?
Dick,
Been there plenty (more than enough) but I guess I just don't shut my mouth in time so the full word comes out followed by a continuous eloquent stream of profanity that would make an Asperger syndrome patient proud and that I am immediately sorry for.....
Dave,
Yes, I am insensitive....Deal with it!
Dave, N9LOV
Member #242
Dave's Diesels:
'02 GMC
