How many grease fittings should I be hitting on my 94 3500 dually? I've never seen a definitive answer.
(yes, I know, "all of them"... I'm lookin' for a number though)
94 3500 Dually Ext. Cab 6.5TD<br />Exiss 3-horse Gooseneck with tie-downs for the bike
Let's see?
Lower Ball Joints 2
Upper Ball Joints 2
Outer Tie Rod Ends 2
Inner Tie Rod Ends 2
Pitman Arm 1
Idler Arm 2
Rear Drive Shaft 3 (Includes u-joints & Slip
Frnt Drive Shaft 2 (If 4 wheel drive)
___________________________________________
16
This should get you in the neighborhood.
Jeff
97 Chev K2500HD 6.5l/4L80E TD Ext. Cab
2000+ AMG Block w/18:1 Mahle Ceramic Coated Pistons - Balanced, DSG HO Injectors, Heath Computer & Boost Control, Kennedy FSD Ext. Harness, Phazer Gear Drive, 4" BD Exhaust w/Downpipe, K&N Air Filter, Isspro Gauges
Mainous
Not quite! If it's a hand shaker, there be one more on the clutch. Bottom of the bell housing just in front of the trans.
