Under the crimped looking thingy is a regular hose barb.The crimped thingy can be cut off or ignored.Add a hose clamp to what you have or change the line and add a hose clamp and you will be good to go.
I have reused many of those kind of fittings.Out in bush where i live you just have to get things done because the parts stores are 100 miles away if i don't have it.
