Results 1 to 5 of 5
Thread: Photo upload test
    Default Photo upload test
    Henry Big Boy Classic .41 Rem. Mag.
    Geneva, IL
    Default Another Test
    And apparently today it worked...
    Bravo!!!
    Rich Phillips
    Member #27
    2019 K-2500 Crew Cab Z71
    That's great! But, I didn't make any changes to the forum format. Don't know why it didn't work for you before. On the downside, it appears the Photo Album may be broken, likely due to recent security upgrades. I'm working on it....
    I noticed that if you wrap the file attachment link with image tags ([IMG] and [/IMG]), it displays the image normally.... here's an example.
    The forum software is supposed to do this automatically. Sometimes it works and sometimes it doesn't, which is why some images display inline or thumbnailed, or as just a link. I suspect it depends on the image metadata and the image processor compatibility. Inline attachments (using the "manage attachments" feature) don't allow tags, but the tag can be inserted with links, even if the link is a previous inline image (such as the previous example). You can also drag/drop images from your desktop, which should be processed correctly. Later versions of the software do this seamlessly.
