The trans goes to a good sized cooler in front of radiator but not connected to the radiator trans cooler. I put new filter in this morning pan was spotless inside so I assume someone else has had the pan of not to many years ago.
I went for a easy 20 mile ride not towing anything and trans temp said a little over 200, in 85 degree muggy weather. Trans temp gauge sender is in test port on side of trans.
I held a thermometer on a stick on the bottom of pan and it said 185 just sitting there idling in park for about 15 minutes.
The images show the normal water temp driving it easy and the trans temp from this mornings easy drive.
Do the factory coolers plug easily? The inside I mean.
