Originally Posted by
curbrider
what i need help with figuring out is why my ecm wont communicate with a scan tool. the ecm is still running the vehicle. it just wont communicate with a scan tool.
As Robyn said, your scan tool won't communicate with the 6.5L ECM due to the fact that your scan tool does not come loaded with the proper 6.5L diesel software. The genuine GM Tech II is the only scan tool I know that works properly.
