Results 1 to 12 of 12
Thread: p42 workhorse Dies at running temp
    Nov 2018
    POPLAR BLUFF
    Default p42 workhorse Dies at running temp
    hello i have a 2002 p42 workhorse recently had feul injection pump replaced and the pcm . had the injection pump back off and the optic sensor replased . it starts and runs fine untill it gets to running temp then it will die and not start up for several hours. been through this thing a number of times with volt meter computer not showing any codes i am at a loss anyone else have a suggestion
    Nov 2018
    POPLAR BLUFF
    its a P42 WORKHORSE vin 5B4KP42Y323340149
    HI
    Classic PMD failure.
    When was the PMD last replaced ???
    I suggest you get a new flight systems PMD and a remote cooler and extension cable.
    Also install a #5 pmd resistor
    Its nearly impossible to see which resistor is installed in the current pmd UNLESS it is remote mounted....
    A little careful fishing can coax the plug off the PMD (Black box on Drivers side of the INJECTION PUMP)
    Resistor goes into the PMD plug socket on the PMD and will only fit one way.
    Be sure to mount the remote cooler in a spot out of the engine bay that has air flow.
    The failure you describe is/was a common issue on the electronic 6.5
    Good luck
    Let us know how things go.
    Nov 2002
    Martinsville, IN
    This sure does sound like a FSD failure. However, if you just had a new injection pump installed as you say, it should have come with a new FSD mounted on the pump. Are you using the FSD on the pump or are you using a remote mounted one?
    One other thing to check: Make sure the lift pump is working.
    Nov 2018
    POPLAR BLUFF
    HI
    Good luck
    pmd was replaced shortly after injection pump as a result of it dying when it gets to running temp
    Nov 2018
    POPLAR BLUFF
    its a non turbo 6.5 if that makes a difference
    Does it have any codes stored?
    When it dies, can you restart it? If not, what has to happen before it will run again?
    Does it die at exactly the same temperature every time?
    Dec 2003
    Yukon Canada
    Quote Originally Posted by tattooOzzy View Post
    What kind of PMD and where is it mounted?
    It is an easy switch to rule it out. I had a new PMD take a dump after very little actual use,the truck would sit for weeks without being used. It was remote mounted.
    Nov 2018
    POPLAR BLUFF
    not showing any codes it will die and wont start for hours untill it cools down usually over night
    Nov 2002
    Martinsville, IN
    Is the lift pump working?
    Nov 2018
    POPLAR BLUFF
    yes left pump works
    Nov 2018
    POPLAR BLUFF
    it runs great starts easy drives fine until it gets to running temp it will stall and not start untill it cools off machiniac has been through it with a volt meter a few times everything is reading like it should
