Thanks John. I'm actually running an EDGE HOT tune that I got from you. Will that work with the SAC nozzles or do I also need a reprogram?
Of course, all of this adds lots of expense, so back to my question about buying some time by using additives to restore some function to the injectors. Any chance this will help? I did the Injector Balance Test and found Injector #7 with a value of -6.8 to -7.0. All other injectors were within -2.5 to +2.5.
Thanks again for your help...
